jake brake for 80s chevy military truck
Old Jul 19, 2012 | 02:59 PM
firstgenfreak93's Avatar
Question jake brake for 80s chevy military truck
How hard is it to instal a jack brake in a 80s chevy military truck. How much will it cost. what will have to be done to make it work. Is it worth the time to install. Will it help stop a 30 to 40 ft goose neck easier with a load on the trailer. what will have to be done to the 6.2 detroit motor with a jake brake put in it.
Old Jul 19, 2012 | 04:38 PM
Mayhem's Avatar
Do you mean an exhaust brake? a jake brake use engine components that a 6.2 lacks and a exhaust brake on the same engine would be a bad idea due too the higher EGTs it would wear out the engine 100 times faster if its tow braking that you are concerned with a good brake controler and a good set of trailer brakes would out weigh the benifits of an exhaust brake.
Old Jul 19, 2012 | 05:18 PM
Thanks for the help i will not do that
Old Jul 20, 2012 | 12:24 AM
bassangler's Avatar
X2 on that Mayham. these are pick up truck not 18wheeler with a detroit and yes they might be a detriot block and so forth . Still a GM product. LOL but yes don't waste your time or $$$$$ . use a good trailer brake and control. Thats what I do to tow my 2011 21ft ranger bass boat.
Old Jul 20, 2012 | 01:03 PM
Thanks for the help. Do you think the truck is capable of pulling a 30ft to 40ft goose neck with a load of 2 tractors on it. It will have a sidewinder turbo and 35in mud tires.I just want a tuff truck for hauling
Old Jul 21, 2012 | 02:58 PM
ts35222's Avatar
I have a m1008 n/a and it will pull about anything, it has 265/75 r16s the only thing I would be concerned about is trailer brakes.
Old Jul 22, 2012 | 01:13 PM
so how much have you pulled with your m1008
Old Jul 23, 2012 | 05:36 AM
Mayhem's Avatar
I have the M1009 Blazer the only thing I have hauled in it is ***
Old Jul 25, 2012 | 12:14 AM
ts35222's Avatar
Its a farm truck so from using it to haul seed, to spray, to hauling skid loaders and tractors is what it hauls. In the fall it pulls 2 wagons out of the field loaded is about 30000 lbs with no pin weight. the rear brakes on these trucks are huge, so stopping power generally is pretty good(if they are adjusted properly and brake booster is good). the rear axle has a ride height sensor/valve which proportions the braking power of the rear axle, which when there is about 3500lbs in the back is pretty nice. The truck will handle quite a bit, just use caution when hauling unfamilliar loads.
Old Jul 31, 2012 | 09:14 PM
sounds like a sweet truck and it is a chevy m1008. Do you think a chevy m1008 will perform with what i want to haul with it like a 30 to 40ft goose neck with tractors or mud trucks on the trailer.
