The brake light problems continue...
Old Jul 19, 2012 | 01:18 PM
Fordguy255's Avatar
Default The brake light problems continue...
So my truck has absolutely no brake lights. I started with new bulbs and that did not fix the problem. Next it was the fuses. Replaced fuse with a new 1 but still no brake lights. Then to autozone for a new brake switch. installed the new brake switch but still no brake lights. Am I missing something? Does anyone have any ideas as to what I should try next? Thanks to everyone in advance for their help. You guys are all great.
Sent from my Galaxy Nexus using Tapatalk 2
Old Jul 19, 2012 | 08:44 PM
Cpdenton's Avatar
do you have your regular rear parking lights? Does anything at all light up on the rear?
Old Jul 19, 2012 | 08:46 PM
Fordguy255's Avatar
When I turn my lights on I have taillights back there they are both working. Its just the brake lights. Whether the lights are on or off I still don't get brake lights.
Old Jul 20, 2012 | 12:31 PM
8seconds's Avatar
One of three things could be the problem:
1. check all grounds for the rear lighting
2. Do you have a trailer lighting plug, take apart and check all wiring inside, repair and
repair and replace as needed.
3. If #2 is true (trailer wiring) check the trailer wiring harness relay under the hood
(driver's front fender, near firewall)
Hope this gives you a starting point....
Old Jul 20, 2012 | 01:03 PM
Fordguy255's Avatar
8 seconds thank you so much for your help. I'll check that stuff as soon as I get home from work
Old Jul 25, 2012 | 01:06 PM
Fordguy255's Avatar
The wiring seems to be ok from what I can see. Where exactly are the grounds for the brake lights? I've been crawling under my truck all morning trying to find them...
Old Jul 25, 2012 | 04:07 PM
Cpdenton's Avatar
I think they are grounded around the plug behind the rear bumper that connects the wiring harness on the frame to the harness on the bed.
On a thread hijacking note, changing out the automatic brake pedal to a brake clutch pedal assembly today, I found my wiring to the brake light switch all melted down with no insulation any more...Guess I need to do some rewiring as well!
Good Luck!
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
Altonlee
Ford Powerstroke 2011-Up 6.7L
Mar 9, 2015 09:27 AM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
yams
Nov 29, 2014 09:25 PM
