How to diagnose/repair leaky injectors?
Old Jul 12, 2012 | 02:10 PM
Spurrit's Avatar
Default How to diagnose/repair leaky injectors?
So, the truck I'm getting sounds like it has the typical D-max issues, with the leaky injectors causing a blown head gasket. Is there any way to fix the injectors, or find out which one was leaking?
Old Jul 12, 2012 | 11:52 PM
2004LB7's Avatar
remove the glowplugs and the FCIM fuse. crank the engine over, the glowplug holes that fuel sprays out of are the ones
Old Jul 13, 2012 | 10:01 PM
BriteWhiteRam's Avatar
leaky injectors cause blown head gaskets?
whats leads you to believe your gaskets are blown?
Old Jul 23, 2012 | 11:24 AM
2500HeavyDuty's Avatar
if the injectors are stuck open that method will work.
there are a few other tests that can be done, like a balance rate test using a scan tool like efi live, or a snapon can tool.
why do you think your head gasket is blown?
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
