2000 f250 died while driving now no start
Old Jul 9, 2012 | 03:03 PM
ju015dd's Avatar
Default 2000 f250 died while driving now no start
00 f250 wont start - PowerStrokeNation : Ford Powerstroke Diesel Forum
please if anyone can help
Old Jul 9, 2012 | 03:56 PM
1999stroker's Avatar
Try the cps? Is it turning over
Sent from my dumb phone!
Old Jul 10, 2012 | 08:48 PM
ju015dd's Avatar
Yes I have a ae scanner on the truck. I have like 150 rpm and no icp press at all. When it did start yesterday I had crazy high icp readings of over 2700 psi at idle.
I repulled ipr and left port on top of hpop resivoire open. I then bumped truck over to see if oil came flying out. To my surprise nothing. Shouldn't I have oil come spewing out of these two locations if I have them out and try and start truck? If not would it be due to a dead srp1 pump?
ok, does anyone out there have for know exactly how to make a icp test plug tool? I have found this nice write up. It pretty much lays it all out there. I just hope my pump isnt dead. But to not have any icp I much either have a dead pump or a huge oil leak somewhere. Injectors and new orings are only a year old.
http://www.fordtechservice.dealercon...iagnostics.pdf
pulled the hpop and found out that the 18mm drive nut was finger tight. And I know I put a torque wrench on it and it has held for right at a year. with almost 20k on the pump. The bolt is almost split in half , like it was cut with a saw zall. ????????? If it is a freakish thing it will happen to me. With all my bad luck.
Old Jul 11, 2012 | 07:06 PM
articfox's Avatar
well it might just be a bad bit of metal i know this sounds far fetched but ive had a nut go like that before it cracked perfectly like that . the only thing i could think of is just a fluke in the metal but it was the oddest thing.
ish1521
Aug 26, 2015 08:42 PM
Mac1997
Jul 13, 2015 05:08 AM
moose2j
Jun 21, 2015 12:36 AM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
Tyler_302
Oct 22, 2014 07:08 PM
