1985 4Runner to MB OM617.950 turbo
Old Jun 27, 2012 | 08:56 AM
yotadiesel's Avatar
Default 1985 4Runner to MB OM617.950 turbo
I have completed my swap and need to do some fine tuning.
The take off is doggy but when the turbo kicks in it is all good. From what I have read adjusting the ALDA will help this out a lot.
My second thing to address is the high end high way speed. It gets up to speed but it seems to stop at 70-75 MPH.
4runner info 4” lift 4X4 5 speed tans
33” tires stock 4.10 gears.
I have adjusted the valves
And replaced the air boost trigger switch on the intake.
The things I need to check are the IP timing I will be doing the drip tube method.
Turbo spools at 9-11 PSI boost. Io have a gauge in the cab.
Engine temp is very cool in all areas. Town high way. driving good or like I Stoll it.
Old Jun 27, 2012 | 08:57 AM
yotadiesel's Avatar
Old Jun 27, 2012 | 02:03 PM
Helel Ben-Shachar's Avatar
With only 110hp, 4.10 gears, offroad tires and the body shape of a cement block, 75mph is all you'll be able to get.
Old Jun 27, 2012 | 02:11 PM
yotadiesel's Avatar
it already is 25% better than the toyota 22RE gaser
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
