vacume pump
Old Jun 26, 2012 | 08:01 PM
92idi's Avatar
Default vacume pump
think my vacume pump is going out, having brake issues and disconnected the line right off the pump and it barely sucks my finger to it, is it possible/okay to use a electric pump instead of replacing the factory one? thinking from a reliability stand point
Old Jun 26, 2012 | 10:13 PM
DieselCrawler's Avatar
the factory one is very reliable. but if u can get a electric one cheap do it. if u need to replace the factory one, they dont come with the pulley. you will need a ps pulley puller to remove and install.
Old Jun 28, 2012 | 09:05 PM
4x4manonbroke's Avatar
you should see around 20 to 26 in. of vaccum .....
Old Jul 3, 2012 | 02:15 PM
Baradium's Avatar
If you're going to look for a new pump the best deal I found was on Amazon.com
Amazon.com: Apdty F4tz-2A451-A Vacuum/Smog Pump For 7.3L Diesel Ford Trucks/Econoline Vans: Automotive Amazon.com: Apdty F4tz-2A451-A Vacuum/Smog Pump For 7.3L Diesel Ford Trucks/Econoline Vans: Automotive
It's listed for the early powerstroke trucks, but the pump is the same as the 6.9 and on. There are TWO differences with this pump from an original one I pulled off my 6.9 truck (1985)
1) The outlet is facing downward at an angle instead of up, you may need a longer hose, especially if yours has been cut previously. On the 6.9 truck I could reroute it, but I'm not sure it is the original hose.
2) The holes that mount it to the bracket are not tapped like the one I took off, I had to source slightly longer bolts and used lock nuts with them.
It's a brand new pump, tag says manufactured in hungary.
I put it on the 6.9 yesterday, and will do the 7.3 truck later today.
Old May 13, 2013 | 10:36 PM
ALWAYSREADYROB's Avatar
will the vacuum pump going out cause the truck to stall ?
Old Jun 17, 2013 | 09:13 PM
NO.... a fuel ump going out will though...
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
greenbomb
Jan 23, 2015 10:36 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
