1995 6.5TD
Old Jun 26, 2012 | 06:04 PM
95heathturbo6.5's Avatar
Default 1995 6.5TD
Hello I have purchased a 1995 6.5 TD Had the truck for a week and it ran great. This past Saturday i was having a loss of power. Truck won't go over 35-40mph. I changed the fuel filter out. Still no better I then noticed I wasn't getting fuel to the filter. I changed out the lp this morning and now have plenty of fuel and the truck starts up and idles I can rev the engine between 1800 to 2800 rpm in Park with no problem. As soon as I take the truck on the road and get on it. The truck goes when I let off the engine dies.. Any ideas?
Old Jun 26, 2012 | 06:36 PM
Mayhem's Avatar
Sounds like Oil pressure sensor??? my truck was doing this a couple weeks ago changed OPS now runs great
Old Jun 27, 2012 | 04:55 PM
Default still no change
Ok so I Purchased and Installed a new oil pressure sensor this morning. Truck starts up and idles fine but as soon as I rev the engine it runs very rough and stalls.. Thinking maybe a bad PMD?? Anyone have any ideas? I'm really hoping its not a bad injector pump. I have a spare pmd and changed it out and the engine still runs the same..
Old Jun 27, 2012 | 05:15 PM
Mayhem's Avatar
Have you cracked open the T valve while it is idling? should have plenty of fuel come out of the hose when this is done it kind of sounds like a lift pump issue
Old Jun 27, 2012 | 05:22 PM
Default GRRRRR
Installed a brand new lift pump yesterday.. Sometime I have fuel at the T and other times I have none.. This has me puzzled??
Old Jun 27, 2012 | 05:25 PM
Mayhem's Avatar
Ok then its a lift pump issue do you know how to do the fuel pump relay bypass ?
Old Jun 27, 2012 | 05:26 PM
No I don't..
Old Jun 27, 2012 | 05:28 PM
Mayhem's Avatar
https://www.dieselbombers.com/chevy-...ont-start.html found it here try this and seee what happens
Old Jun 27, 2012 | 08:03 PM
I'm going to run a hot wire direct to the lift pump and see if the truck will stay running like that.. If thats the case I will just run a toggle switch to the hot wire and I will manually start and stop the pump..
I hooked a hot wire to the lift pump had constant fuel to the T still truck idles and still won't take any fuel. Thinking I might have a bad injector pump or something else going on.. Anyone have any ideas please?? Truck has been down for 6 days now??? Almost wishing I never bought it. Hoping its something very simple that I'm over seeing...
Last edited by 95heathturbo6.5; Jun 27, 2012 at 08:03 PM. Reason: Automerged Doublepost
Old Jun 30, 2012 | 02:04 PM
knitehawk's Avatar
just bypass the relay under the hood to an accessory fuse. (about 2 inches of wire and it will use the ignition switch. no muss no fuss.
