rear main seal leak
Old Jun 21, 2012 | 02:03 PM
docweld's Avatar
Default rear main seal leak
My 2000 f-350 7.3 with only 78,000 miles on it looks like it has a rear main seal and front cover leak. can I use ( Bar's Leaks Rear Main Seal Repair (p/n 1050)) to see if it helps or will it hurt the injectors?? I have the oil drained out now. I called Bar's and asked them and they said they would into it and call me back. Just wanted to know what you think.
Bar's called me back and said I can use it in my truck and would need to put 3 bottles in. I just do not know if I like the idea of putting it in. any ideas of what I should do to stop the leaks with out pulling the trans?
Old Jun 21, 2012 | 03:16 PM
ToMang07's Avatar
DO NOT do that. Oil additives mess up and can severely damage the HEUI system.
Second....shouldn't have drained the oil... chances are very good you have an oil leak somewhere in the valley, either the HPOP, HPOP Lines, Turbo/Pedestal, etc. You need to clean off the engine to locate the leak.
Old Jun 21, 2012 | 04:31 PM
docweld's Avatar
Thank you!! I know there was a reason I did not want to put it in. I put new oil in and will wash everything down and hope to see where it is coming from. like I said the truck is a Feb 2000 but only 78000 miles on her.
Old Jun 21, 2012 | 11:32 PM
Fourwheelrevolver87's Avatar
Clean up the front and back of the pan well, my 99 leaked where the pan seals to the front and rear housings....
I 2nd tomango, could be from the valley. Possibly turbo pedistal o-rings leaking or the ebpv piston...hpop...intake plenums...
Def. DONT use the bars!
Old Jul 27, 2012 | 10:32 AM
flathead jack's Avatar
check the oil plugs in the back of the head they will look like main seal leak
Old Jul 27, 2012 | 11:06 AM
CSIPSD's Avatar
Main oil leaks are EXTREAMLY RARE for these trucks.
Its more then likely something else.
makuloco2000
Dec 20, 2015 11:19 PM
yfzrunner
Sep 17, 2015 05:23 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
wildbill
Jan 31, 2015 11:14 AM
ash23k
Dec 30, 2014 08:31 PM
