5 speed cummins swap
Old Jun 16, 2012 | 01:05 AM
codycatract's Avatar
Default 5 speed cummins swap
i have a 97 crew cab f350 LB. it has the 7.3 and e4od. im doing a 92 cummins with nv4500 or zf5, whatever i find first, my question is pedal assembly. where can i find them and what all years are compatible for my truck? and i need them from gas engine truck so the pedal is for cable and linkage right
Old Jun 17, 2012 | 12:19 AM
Fourwheelrevolver87's Avatar
Done quote me on this but you should be able to use a clutch pedal assmbly from 87-97 roughly...for sure from 92-97. I dont know about 80-86 though...both the zf5 and nv4500 are hydraulic, so you will need the hydraulics (master/resivor, line and slave cylinder) for which ever trans you end up using. Wait, I think you are refering to the throttle pedal as far as cable/linkage...should be able to fabricate the existing throttle to accept the cable from the cummins...or ya a pedal out of a gasser. Havnt done this exact conversion but thought id try to help.
Old Jun 18, 2012 | 02:25 PM
93_Fummins's Avatar
You'll need a 92-97 gas or 92-94 IDI diesel pedal assembly (the IDI's are cable and adapt to the 12valve pump linkage pretty easy, IMO). You may want to snag the steering column from sourced manual donor truck too. IIRC, the 87-91 pedal assemblies are slightly different, but I don't remember for sure so don't quote me on that one.
Old Jun 18, 2012 | 06:32 PM
great info thanks alot for the help!
Dertyd
24
Jun 7, 2015 02:45 PM
F250MACH
Apr 26, 2015 05:19 PM
mcclusk
Feb 21, 2015 09:50 PM
stephenthinnes
Dec 6, 2014 11:54 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
