Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Gear Oil
Old Feb 20, 2008 | 09:50 AM
JakeDeisel's Avatar
Default Gear Oil
I know that gear oil is not ment to be burned. But If you put a quart of new gear oil in everytime you fillup will it hurt anything.
Looking for a cheap active of more lub in the fuel and I can come across gear oil cheap.
Old Feb 20, 2008 | 10:51 AM
2500HeavyDuty's Avatar
i have never heard of some one putting gear oil in their tank, but a quart of 2-stroke oil works and wont hurt anything cause it is meant to be burned and it is ashless.
I used to throw some in every other tank until i bought some Stanadyne.
Old Feb 20, 2008 | 10:58 AM
DBogo's Avatar
gear oil is really thick it will probably just sink to the bottom of the tank and take a while to dilute, your better off with 2 stroke
Old Feb 21, 2008 | 10:34 AM
GBWELDING's Avatar
Wouldn't run my 02 without 2 stroke in the tank, cheap and no additive I've seen can match it for lubricity. I do add a cold flow improver in the winter.
Old Feb 21, 2008 | 10:36 AM
Whit's Avatar
Site Mascot
dont do it man
way to many additives in there
use 2 stroke oil its ashless and ment to be burnt .............1 oz per gallon
Old Feb 21, 2008 | 07:09 PM
JakeDeisel's Avatar
Thanks guys looks like I am going to go with the 2-stroke oil.
Old Feb 21, 2008 | 08:58 PM
saab9k's Avatar
Gear oil, used work great in waste heater i have in my 8000 sq shop, clean the ashes out 2 - 3 times a year. Depending on hrs of use
Old Feb 22, 2008 | 02:55 PM
JakeDeisel's Avatar
Just thinking about this again still going to use 2-stoke oil but what does the ash do. Does it plug up the injectors?
Old Feb 26, 2008 | 02:43 PM
06Dodge's Avatar
Everyone uses ash less 2 cycle oil so that they don't have to worry about ash problems.
Old Mar 16, 2008 | 02:39 AM
01quadcab's Avatar
I have been using the 2 stroke for close to a year now and it gets better mileage and it seems to be a little more quiet than it used to. people that don't listen to it all the time think I am nuts
