loading up and haze
Old Jun 15, 2012 | 12:03 AM
CMCA Swartzkrautheim's Avatar
Default loading up and haze
ok so i have ts6 with the chip its got a heavy bluish white haze
<iframe width="560" height="315" src="http://www.youtube.com/embed/bIeGB71GxkA" frameborder="0" allowfullscreen></iframe>
vid2
<iframe width="420" height="315" src="http://www.youtube.com/embed/6WMlpU5uJIM" frameborder="0" allowfullscreen></iframe>
without the chip i have no haze and nice smooth idle
<iframe width="420" height="315" src="http://www.youtube.com/embed/m2KgVfExEf8" frameborder="0" allowfullscreen></iframe>
any ideas im gonna get fp gauge soon as i can and a rebuild kit too...
Old Jun 15, 2012 | 11:32 AM
CSIPSD's Avatar
YouTube - Broadcast Yourself
Ts back in loadin up - YouTube
Old Jun 15, 2012 | 12:10 PM
CSIPSD's Avatar
Need to pull codes, sounds like you have a dead miss... When you remove the chip does it run fine?
Did you get a chip with single shot tuning on it?
Old Jun 15, 2012 | 09:15 PM
thanks for the fix on the vids, with removed its smoother but seems to be higher idle, ill try too get scanned soon same chip as before just seemed too slowly come on... yea i cant really remember it happening all the sudden at all... im wantin a contribution test right?
Old Jun 15, 2012 | 09:53 PM
CSIPSD's Avatar
Yes, that would help. Who did your injectors?
Old Jun 15, 2012 | 10:27 PM
i rebuilt em new stock plunger and barrel with 80 percent nozzles, electrically they were good but im almost wonderin if i didnt have a bad poppet valve oil side on one...
Old Jun 15, 2012 | 11:32 PM
CSIPSD's Avatar
How long have they been installed?
The white haze is from low ICP pressures at idle with the 80% nozzle. But it sounds like you have a bad injector or three...
Old Jun 15, 2012 | 11:38 PM
Bout 2k if I got custom tunes do u think it help? Why would it run better without than with chip?
Old Jun 16, 2012 | 12:13 AM
CSIPSD's Avatar
Its hard to say...
You could chat with PHP and see what they think. What ever tuner you pick make sure you explain exactly what you have injector wise.
Check to make sure everything is installed and plugged in properly. Can you run a buzz test?
Old Jun 16, 2012 | 12:20 AM
Yea soon as I can get back too my buddy's shop, does anyone do free reburns once u buy customs without buyin chip from them?
