Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
Small oil leak
Old Jun 14, 2012 | 10:49 AM
jc8825's Avatar
Default Small oil leak
The LMM forum is down, but this issue should be universal. I noticed today that I have a small oil leak no higher than the pan and it is a spot on the front passenger side corner of the pan and is only bad enough to run down the pan a bit, it does not drip. Also, my engine does not use oil and is currently at the top of the 'F' on the dipstick. Is that normal?
Old Jun 14, 2012 | 09:22 PM
BriteWhiteRam's Avatar
is it possibly transmission fluid? I know that the transmission cooler lines leak on the passenger side
Old Jun 15, 2012 | 10:50 AM
jc8825's Avatar
The transmission cooler lines were replaced about 5K ago, so no leaks there, and it is definitely oil. It is black and in a spot where it looks to have been for a while it has thickened to grease.
Old Jun 15, 2012 | 11:25 PM
could be just a slight leak in your oil pan gasket?
Old Jun 16, 2012 | 10:22 AM
jc8825's Avatar
I guess it could be. How hard is it to fix?
Old Jun 18, 2012 | 10:42 PM
that I couldnt tell you, Sorry
cummins Pride
Sep 28, 2015 12:11 PM
big Mikey mike
Jun 18, 2015 08:44 AM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
