boost gauge hook up
Old Jun 12, 2012 | 07:44 PM
docweld's Avatar
Default boost gauge hook up
I tapped into the map sensor to intake line and I would get to 28lbs boost, I would run out of rpm before boost. I do have the waste gate line with a hole in it. I moved the boost gauge line to a hole I drilled and tapped in the intake and now I only get 22lbs of boost before I hit top rpm. any thought why?? I am going to hook up a 2nd boost gauge in the same place as the first to see what happens.
I also did open my ebpv and tube, they were blocked. and opened the fuel restriction in the filter and heads. it spools up from 1500-3500 much much faster but I can tell at around 2800-3000 the boost stops
Old Jun 12, 2012 | 07:46 PM
fordornothing's Avatar
22 psi is more accurate. that's the max the PCM will alow before it defuels.
Old Jun 12, 2012 | 08:09 PM
docweld's Avatar
yes, I have read that 22 psi is the max, but I never ran out of boost before I moved it. could the boost gauge line tapped into the map line been faking out the map to see less boost then there really was?? that is why I am going to hook the 2nd one up. just wanted to know if anyone had this happen.
Old Jun 12, 2012 | 09:18 PM
CSIPSD's Avatar
take a picture of the two places you are getting your boost readings from...
Is your truck stock?
Old Jun 13, 2012 | 11:28 AM
docweld's Avatar
new boost gauge point. 22 psi @ around 3000rpm
old boost gauge point, 28psi @ 3500 rpm
Old Jun 13, 2012 | 12:14 PM
CSIPSD's Avatar
Its the same location... So if you saw a differance you had a leak before or after.
I would be really suspect of 28psi on a stock truck.
Do you have a chip or other power adder?
Old Jun 13, 2012 | 12:38 PM
docweld's Avatar
yes, hypertech power programmer 3, stock down pipe but 4" from that out in front of back wheels, BD air system, pin hole in the waste gate line.
I just hooked up a 2nd boost gauge and see 24 psi in the map hose and 22 psi in the spider pipe. I think you are right I must have had a leak and it was faking out the map sensor. maybe if I can do it again I will not have to spend $50 for the kit.....????
I am going to try more things to see.. thanks!!
Devon7.3
Sep 22, 2015 07:59 AM
stewart.william.c
Feb 11, 2015 01:39 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
mt_wi86
Oct 7, 2014 01:13 AM
