New truck what should i do maintenance wise
Old Jun 10, 2012 | 06:57 PM
cumminsdzlfan's Avatar
Default New truck what should i do maintenance wise
Like the title says i just bought a new truck. Its a 2006 3500 4 door 4x4 with an automatic transmission. What should i do maintenance wise besides change the oil, oil filter, fuel filter and maybe the air filter. Truck did have a light programmer on it for a while but was taken off prior to me getting it. It had one of the injectors replaced about two years ago with no problems since then. Thats the only major thing i know of that it had done. Thanks
Old Jun 10, 2012 | 06:59 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
have the tranny serviced.
Old Jun 11, 2012 | 07:22 PM
by that i'm assuming you mean change the fluid and the trans filter right?
Old Jun 11, 2012 | 08:20 PM
diesel pap's Avatar
yes fluid, filters and adjust bands if needed.
jshblain's Avatar
Transfercase- drain and fill with ATF 4. And both differentials with limited additive in the rear
Old Jun 11, 2012 | 08:22 PM
I would get a 2 or 3 micro fuel filter so you don't have to buy a $2000+ set of injectors.
Old Jun 13, 2012 | 02:49 PM
Anything else? Can any transmission shop adjust the bands? Is there a 2 micron filter for the stock location?
Old Jun 13, 2012 | 04:18 PM
dmaxkiller's Avatar
^ no you will have to buy a aftermarket lift pump which isnt a bad idea either and then use a 2 micron filter on it. fass or airdog are really good. even a raptor pump isnt bad..
doublehbar
13
Aug 9, 2015 12:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
