cold start problems?
Old Jun 9, 2012 | 06:06 PM
97t444e's Avatar
Default cold start problems?
in the moring when i go to start the truck it just dumps white smoke but it will finally after cranking it for awhile and once it starts it runs fine any ideas?
Old Jun 9, 2012 | 08:10 PM
twinboys's Avatar
glow plugs / relay
Old Jun 9, 2012 | 08:24 PM
RanchhandTCR's Avatar
What he said, have you ever replaced glow plugs and the relay on your truck?? If not its time... or a good place to start
Old Jun 9, 2012 | 08:47 PM
97t444e's Avatar
i just replaced the glow plugs in april, the strange thing is this first happend after i put a new valve cover gasket on the passenger side. I will start with a new relay and see what happens and also sometimes when i go to fire up the truck it wont start and the check engine light comes on while im cranking but ounce i turn the key off and try again it starts so any ideas on that???
Thank you
Old Jun 9, 2012 | 09:09 PM
fordornothing's Avatar
where do you live? it's june. you shouldn't be having cold start issues
Old Jun 9, 2012 | 09:24 PM
maybe the connection in your valve cover gaskets are bad??
Old Jun 9, 2012 | 09:37 PM
97t444e's Avatar
i live at 10000 ft in the mountains, it gets down to the low 40s and high 30s at night alot. But if the connection was bad wouldnt i be able to tell??? cuz to me it runs fine once it starts.
Old Jun 9, 2012 | 10:10 PM
put a test light on the GPR. if that i fine then ohm. out the GP pins at the VC plugs.
Old Jun 9, 2012 | 10:36 PM
Fordguy255's Avatar
I'm having kind of the same problem but here it's temps in the 70s and 80s. Takes a couple cranks to get going and runs rough for about 5 seconds before idling fine. Truck runs great afterwards and starts easy when warmed up. I would think it would fire right up when it's that warm outside. Let me know if you get it figured out.
I am here: http://tapatalk.com/map.php?5q5bhs
Old Jun 10, 2012 | 03:01 PM
97t444e's Avatar
i went to start the truck today and it started fine this time but im still going to check the relay
i went to start the truck this morning and it acted up and would not start on the first attempt but the second attempt worked and it fired right up but i heard a clicking sound so i popped the hood and put my hand on the GP relay and could feel it clicking and after about 30 seconds it stopped, is it suppost to be doing that?
