01 cummins small miss
Old Jun 8, 2012 | 01:07 AM
mike12v!'s Avatar
Laugh 01 cummins small miss
I have a 01 cummins with a ppe lift pump and a diablo powerpuck truck runs strong but about 50-75mph it has a miss too it i changed the fuel filter today and run some injector cleaner thru it also can someone point me in the right direction
Old Jun 8, 2012 | 01:10 AM
H.R.D's Avatar
I would remove the powerpuck and see if that changes anything. What fuel pressure are you seeing from your LP?
Old Jun 8, 2012 | 12:55 PM
mike12v!'s Avatar
I dont have a fuel pressure gauge i m gonna put one on it where would it tap into my pump is on the frame rail
Holding it steady at 70it feels like a small hesatation than when you put the pedal too the floor its gpt all kinds of power
Old Jun 8, 2012 | 04:24 PM
H.R.D's Avatar
You can buy an adapter to plumb in the FP sending unit at the inlet of the VP. This will give you the best reading of FP.
Does your RPM gauge represent the miss?
Old Jun 8, 2012 | 04:55 PM
mike12v!'s Avatar
yes the rpm does slightly jump during the miss when you stomp on it though its got all kinds of power
Old Jun 10, 2012 | 01:04 PM
mike12v!'s Avatar
Could it be a tps maybe
Old Jun 10, 2012 | 02:45 PM
H.R.D's Avatar
It could be, it could also be your Camshaft Sensor.
Old Jun 12, 2012 | 06:36 AM
mike12v!'s Avatar
How can i rule them out i dont have a cel on or anything
Old Jun 12, 2012 | 04:19 PM
H.R.D's Avatar
Try the below procedure and see if helps any.
File Type: pdf
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
