Low speed surge
Old Jun 7, 2012 | 08:45 PM
jshblain's Avatar
Default Low speed surge
Hello everyone, I've started noticing a low speed surge seems around 2nd gear around 25-30 mph. I've talked to a couple people about this and they all say it's pretty normal. I was just wondering if anyone has found a cure for this. Please let me know any insight you may have. Thank you
I haven't update my sig yet, little info on the truck
Intake tube baffles removed, straight pipe with cat still in, diablo predator performance tune. Truck has 98k miles. Auto trans (factory)
Old Jun 7, 2012 | 09:31 PM
Anguss's Avatar
Define surge....? Shuttle Shift, Rev & No-Go, feels like it jerks bck and then fwd a gear? Stock Dodge Tran often times isn't the problem, its in the sending signals. Shift enhancer may help.
Old Jun 11, 2012 | 08:11 PM
jshblain's Avatar
In low speeds around 10-25 mph after shifting in to second. It's hard to tell but feels like its either searching for second or cant get second to apply fully. I was thinking governed pressure switch and transducer? Any thoughts? Also if anyone agrees do you know of an upgrade for those switches that can be done? Thanks
Old Jun 11, 2012 | 09:48 PM
Anguss's Avatar
This is commonly refereed to as Shuttle-Shift or 1-2-1-2. Even with a Goerend, the sending signals can get messed up and this happens. The occurrence tends to be somewhat predictable for the most part, as commonly when no load or very light load, light to moderate acceleration. Below is apic of two different ones (in amongst a my growing collection of tuners and whatnot).
https://www.dieselbombers.com/attach...1&d=1339467793
Old Jun 11, 2012 | 10:14 PM
Anguss's Avatar
Shift Enhancer is the small silver box with 3 buttons/LED indicators for Daily, Towing, and Performance, the rectangular module is TS Performance Shift Master that works similar with a dial instead of buttons. I have found this to work great, and depending on the HP/Tq of each different program our tune you're running, it completely eliminates the issue you're describing. They with by decreasing it increasing the parameters of shifting, and prevents the Shuttle-Shift or hesitation which tend to worsen with increased tuning. It's very irritating and makes others at stop light think you have a stick shift and missed a gear
Old Jun 12, 2012 | 08:13 AM
jshblain's Avatar
Ok sounds good looks like that's the rout I'm gunna go. Thanks
Old Jun 12, 2012 | 11:25 AM
Anguss's Avatar
You're welcome.
If you have doubts as to condition of transmission, it's cheaper to get it checked out (I have never had any problems and top notch Customer Service with Goerend, Dave will lend advice, and not everyone needs a FB triple disc).
It's a matter of certain peoples'opinion that the Shift enhancers cover up future problems, and anyone changing their Torque Management needs this, but we all know how our stock trannies work out when we start maximizing the potentials that our engines have, and we all have to pay to play.
I would look for a used one, it'll do the same thing. If you need, I have 2 different ones, and have a bunch of stuff, that I need to get rid of, I have a used one Shift Enhancer or a NIB TS Shift Master.
Old Jun 15, 2012 | 09:01 PM
jshblain's Avatar
Message me on what you want to get rid of and how much including shipping to 34120.
Old Jun 16, 2012 | 10:59 PM
dmaxkiller's Avatar
might want to check out the fca. iv heard it causes surging
Old Jun 17, 2012 | 07:25 PM
jshblain's Avatar
What is the fca?
