Wont start?
Old Jun 3, 2012 | 06:52 PM
vettedon's Avatar
Default Wont start?
95 Chevy 3500 2 wheel 6.5
Was starting and doin fine, then a chipmunk chewed the wires off the crank sensor (3) at the block. Before I found it, would only crank and would only start with a shot of either. but when hot would start on its own after 15 full seconds of cranking. Replaced sensor and no change in symtoms. Could have the raw wires chewed shorted or blown a fuse? Checked fuses on drivers side dash and inner fender under hood. All good. Dahhh.. what now?
feelin kinda stupid
Don
Old Jun 4, 2012 | 01:25 PM
CSIPSD's Avatar
Moved it down here for ya...
Welcome to the site, not sure how many 6.5 guys we have but hope someone can help ya!
Old Jun 4, 2012 | 02:17 PM
vettedon's Avatar
Me too! thank you
Old Jun 4, 2012 | 03:27 PM
ebarresi5894's Avatar
there is a possiblilty on the raw wires. any more info you can give on like how it starts or runs? any DTCs?
Old Jun 5, 2012 | 08:02 AM
vettedon's Avatar
Motor cranks fine but will not start when cold without a shot of start fluid. Runs normal. When warmed up, shut off and will start only after about 15 seconds of cranking. Then it runs normal. Cranking is very good with good batterys. Bled fuel system for air
Thanks for note
Don
Old Jun 5, 2012 | 08:07 AM
hmm, could be a bad PMD.
DONT USE STARTING FLUIDS IN 6.5
how are your glow plugs?
what color is exhaust smoke?
Old Jun 5, 2012 | 12:08 PM
vettedon's Avatar
This problem happened quickly. Didnt check glow plugs since never an issue. Still wouldnt start in 90 degree temp. little to no smoke as usual. Runs normal and clean after starting.
Old Jun 6, 2012 | 08:19 PM
Hmm could be the starter ready to go mine did that cause it couldn't spin the engine fast enough. Could be a leaking injector too what color smoke on start up? Do they sell pig tails for that wire it could be the connection still
Old Jun 8, 2012 | 05:36 AM
vettedon's Avatar
The starter spins like new. Not an issue. not much smoke at all. This problem happened sudden. No preformance issues or start problems. Think that chipmunk did the dirty deed
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
