95 PSD still cutting out !!
Old Jun 2, 2012 | 10:00 PM
cwbydw's Avatar
Default 95 PSD still cutting out !!
My 95 F250 powerstroke has a random cut out. If it does die it will start right back up. Will act up hot or cold, idleing or driving. Have replaced: PCM, IPR, ICP, UVCH's and pigtails, new baby swamp injectors, foot feed assembly, several CPS, new lift pump and fuel filter, changed oil and filter, and cleaned the entire FPR assembly and blew out the fuel lines.
Nothing has made a difference. Also replaced all battery cables and ignition switch. Added one extra engine ground cable. Never looses power, just cuts out and comes back to life. No codes present. At 3000rpm the hpop is 1100psi w/ duty cycle 20%. Lpop shows 50psi on mechanical gauge. When it does die and has long start, checked the hpop and it was full, so was fuel filter housing . 50-60psi fuel pressure. Any ideas ???????
Old Jun 3, 2012 | 03:19 AM
97t444e's Avatar
have you followed all the wires and looked for any damage
Old Jun 3, 2012 | 08:46 AM
cwbydw's Avatar
I took the wiring harness out and completely went through it when i put the new pigtails on for the uvch's. Couldnt find anything that looked bad.
Old Jun 3, 2012 | 02:19 PM
CSIPSD's Avatar
Your 1100icp pressure reading, I am assuming that is no load just free reving?
Have you run a buzz test?
Old Jun 4, 2012 | 09:00 AM
cwbydw's Avatar
Yes , those readings are setting in the shop in park. Truck has passed multiple buzz tests as well a cylinder contribution test. When the truck runs right, it runs GREAT. It will set you back in the seat! The swamp injectors really do their job!!
This problem started a couple months ago and nothing I have changed has made it better or worse. Leaning towards trying a new lpop, but it has good readings on the gauge
Old Jun 5, 2012 | 08:10 PM
cwbydw's Avatar
Any other ideas ????
Old Jun 5, 2012 | 09:56 PM
95powersmoker's Avatar
Are you running a chip? Maybe a loose connection there?
Old Jun 6, 2012 | 08:12 AM
cwbydw's Avatar
Did not have a chip in when problem started, has a TS 6 position chip in now.
Old Jun 6, 2012 | 11:18 AM
Well if you have oil in your HPOP res everytime you look, I wouldn't be worried about the LPOP...
Where did you get the CPS that your using now?
Old Jun 6, 2012 | 12:53 PM
cwbydw's Avatar
It's a black one from napa. Had grey one in it as well. never noticed a difference between the two.
