Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
Some lights work, some dont
Old Jun 2, 2012 | 03:35 PM
ndelaney's Avatar
Default Some lights work, some dont
I just bought a 03 Ford with a wiring issue hopefully its not too hard. I wanted to try to figute it out before I take it to somebody.
The turn signals, hazards, break and brights do not work. The running lights front and back work and the break light above the rear window works. All fuses are good. That I can see.
Today I got in in it to start it and it would not start. Battery was not dead just low, been sitting for 3 days, like something was slowly draining it. Im not really sure where to start. Any ideas greatly apprecitated.
Thanks
Nick
Old Jun 3, 2012 | 04:34 PM
minncountryboy's Avatar
Check for cracked, broken wires, may a hack job of wiring repairs.. it sounds like somthing is constantantly pulling juice. And if its got a tow package. I'd check the wiring for the trailer, i bought a truck were when it rained everything got fucked up and it was just in the trailer wiring job. Could be a number of different things. But id definatly check your wiring first off.. that usually a good start.
Old Jun 5, 2012 | 05:12 AM
Deezel Stink3r's Avatar
You need:
A multimeter.
Set the multimeter to the ampere setting. Choose a range up to 200mA.
Disconnect the positive battery connection.
Make sure everything in the truck is switched off. This is important! Otherwise the current draw will destroy the meter!
Now connect the plus pole of the meter with the plus pole wiring connector.
Then connect the minus pole of the meter with the positive battery pole!
If a battery drain current exists, you can see that amount now on the meter display.
Start pulling fuses until the drain disappears.(To read as the meter drops to zero.) Now you have isolated the faulty circuit where power is consumed. Check that circuit. It is usually either the radio memory or the ECM. Both of them must consume current to maintain their memory.
Faulty circuits do also consume currents.
An calculation example:
a small current as a faulty relay consumes up to 100mA per hour.
Within 24 hours the faulty relay has consumed 2.4Ah- a 50Ah battery is drained completly within 2 weeks, since batteries are mostly charged up to 2/3.
I hope this helps a bit.
Old Jun 11, 2012 | 01:23 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Sounds like a pain in the butt I hate wiring issues
Old Jun 18, 2012 | 08:11 PM
I love wiring! I used to hate it.. but now I love it!
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
Rcracer78
Apr 20, 2015 12:49 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
