Fuel Economy Mystery
Old May 26, 2012 | 08:39 PM
Dwhal's Avatar
Default Fuel Economy Mystery
Hey everyone!
I recently purchased my first cummins and couldn't be happier with one exception - the fuel economy.
I realize that a truck is a truck, and hoping for 'good' fuel mileage is pissing into the wind, but something seems up.
I have a 1998.5 5.9 24v. 220,000 kms. Auto (Fresh rebuild)
Levelling kit
33x12.5 BFG M/T's
3" Straight pipe exhaust
I recently replaced the fuel filter, oil, air filter, and ran some diesel treatment through the engine.
I'm averaging about 6 km / 1 L, and if I'm lucky 700 km to a tank.
I have 4 close buddies all with the same generation motors who are running 35" tires and they all average between 800 and 1000 kms a tank.
I know my speedo is out by about 17% (100km/h is actually 117 km/h) and have factored this into my calculations.
I run Howe's Meaner Power Cleaner with each tank and never run it passed 1/4 tank, so I'm not sucking sludge into the filter.
I drive it like a little old man, so driving style shouldn't be the issue.
It drives great, doesn't seem to be lacking any power and has no apparent issues, but I know this vehicle is capable of more.
Currently I'm thinking injectors or injector pump, but I'm still new to this so I was hoping you guys might have some idea's or directions to look in.
Thanks everybody!
- Drew
Old May 27, 2012 | 09:18 PM
01quadcab's Avatar
what lift pump is on your truck? Do you have any gauges? You could have low fuel pressure thus killing the injection pump would lead to poor fuel mileage. I am not familiar with the fuel additive your using so you can always try not using it for a tank or 2 and see what happens. Also found that for best mileage in these change the differentials over to synthetic gear oil helps.
Old May 27, 2012 | 10:13 PM
Whit's Avatar
Site Mascot
if over 100k do and overhead .also clean the MAP sensor
if you have a boost gauge watch it or look at it as a work gauge..the higher the boost the worse the milage....I can start out and get to 65 mph without going over 8psi boost
Old May 28, 2012 | 08:22 PM
Dwhal's Avatar
No gauges, I'm investing in a Juice w/ attitude in the near future, so that will cover those bases.
I'm unsure of which lift pump I have in mine, reccomendations?
Old May 29, 2012 | 12:17 PM
chuffysplace's Avatar
maybe look into a valve adjustment too.
Old May 29, 2012 | 09:49 PM
01quadcab's Avatar
you need something better than stock I really like Fass systems myself. something to keep it at 16psi would be a good thing. get that edge fast so you know fuel pressure or your going to spend 1k for a injection pump with no installation or anything
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 5, 2014 03:10 PM
