05 6.6 fuel in oil
Old May 25, 2012 | 06:18 PM
Xcreek's Avatar
Default 05 6.6 fuel in oil
Changed oil last week and removed about13 quarts. Thought my son had over serviced so put in 10. Drove about 75 miles and checked oil and again well above full and running a bit rough at idle, headed for the house and low oil press warning came on at idle, short drive to the house and drained the oil and again LOTS came out. Looking for some guidance here, still has original injectors at 124k. No noticeable smoke.
Old May 25, 2012 | 09:16 PM
j johnson's Avatar
sounds like an leaky fuel injector...get that checked asap!!!!
Old May 26, 2012 | 07:28 AM
Xcreek's Avatar
How do I check rail press, no shops open this weekend and need to start work on this, as it is my primary vehicle. I am not showing any codes from my OBD, but the unit shows fuel system monitors as NA??
Would like to understand where to connect gauges on common rail. I think one of the local parts houses has the proper guages, as I understand it it needs to have range above 20000psi just want to be sure of the fittings and connections.
Old May 29, 2012 | 01:57 PM
dmaxjenn's Avatar
IT'S A GIRL!
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
bigredcummins
Jan 4, 2015 04:37 PM
