rear ends
Old May 21, 2012 | 09:25 PM
cumminskid92's Avatar
Default rear ends
I am getting ready to start my drag truck build. its gonna be a tubbed 2wd short bed. i was just have no idea as to what rear end what will handle the power. 800-1000ish. i have a chance to buy a ford 9 inch really cheap but has already been narrowed and has wheels with 18" s licks on it. will a 9 inch hold up or be built to hold up. or would i just be better to start with my dana and build it.
Old May 22, 2012 | 05:43 AM
welderboy250's Avatar
My opinion would be to use what u got or a 14 bolt gm but I'm no racer so take it for what it's worth.
Old May 22, 2012 | 07:54 AM
Eddiebuntain's Avatar
A good 9 inch ought to hold up pretty good. That kind of power, about anything is gonna require maintainance, unless you go real heavy duty, which doesn't necessarily fit the drag racer theme. That's just my $.02
Old May 22, 2012 | 04:58 PM
thanks for the input. can my dana be made stronger than a 9 in
Old May 23, 2012 | 03:49 AM
That's a 60, right? I think their about equal, comes down to how you build 'em, brand loyalties, and price. You already have the Dana, but it'll have to be modded, and I think quality Dana parts are more expensive than comparable 9 inch parts. You might be able to find better deals than I've seen, good luck either way
Old May 23, 2012 | 05:25 PM
i think it is a 70. its a 1 ton truck
Old May 23, 2012 | 08:06 PM
If its a factory diesel its a 70u
Old May 23, 2012 | 08:25 PM
mss3808's Avatar
my opinion if u could get the 9inch at a good deal that whould be my choice parts cheaper and more avalible also easier to work on
Old May 23, 2012 | 09:17 PM
tower_ofpower's Avatar
SRW Dana 80 with a spool and a good sturdy differential cover; I've heard the axle shafts in the 70's are it's weak link and aftermarket is expensive compared to 80's that can handle it right out of the box. Obviously you're going to want to get your gearing dialed in and with any luck you might be able to find an axle with the desired gearing
Old May 29, 2012 | 08:38 AM
i think im going to go a head and get the 9 in since it has already been narrowed and has disk brakes on it. i think i can get it for next to nothing anyways. if i blow it up then i will build my 70 or try to find and 80. thanks for the help
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
dougcarlo
Oct 18, 2014 03:15 AM
