diesel4
Old May 20, 2012 | 05:42 AM
diesel4's Avatar
Default diesel4
my a/c keeps popping the fuse ane then blows air thru the defrost ports, any ideas?
Old May 20, 2012 | 06:25 AM
1999stroker's Avatar
Don't know about the fuse issue but the air through defrost sounds like you have a vaccum leak. There are little rubber line going from your hubs to a solenoid on the passenger fender and it goes through a box. You can either trace the leak and rebuild the hubs with new gaskets or replace the hubs with warn hubs and cap the vacuum lines.
Old May 20, 2012 | 08:12 AM
diesel4's Avatar
thanks for the quick reply, ill check that out and see what happens.
Old May 20, 2012 | 09:16 AM
No problem, also what year truck etc? And that only applys if it's 4x4 I thin the solenoid I mentioned is the vaccum pump or something close to that looks just like a starter solenoid theres a thread in here from when o had same issues.
Old May 20, 2012 | 10:37 AM
diesel4's Avatar
my truck is a 1999 f250 ,7.3,4x4. i found the soleniod/vaccum pump. the vac, lines to the hubs was a little looseso ill replace somes lines and go from there, thanks again for your help. and this web site.
Old May 20, 2012 | 11:41 AM
Yup,you could try plugging them with a bolt just to see if that fixes your problem
Old May 22, 2012 | 02:16 AM
diesel4's Avatar
when i did replcae the fuse the ac started working right, i still will try your suggestions,thr fuse thing has me wondering.
Old Jul 14, 2012 | 02:16 AM
diesel4's Avatar
found the problem it was a vaccum pump on the passenger side by the hood spring. finally some a/c in this 100 degree heat.
