Construction Equipment Discussion of Diesels Used for Construction - Bull Dozer's , Back Hoes , Skid Steers , Track Hoes , Dump Trucks
JD 6068 SUCKING AIR
Old May 19, 2012 | 07:02 AM
CCC1971's Avatar
Default JD 6068 SUCKING AIR
I have an I/R 125kvw that will suck air and has to be bled every couple of days to start. So far I've replaced every fuel line and filter, to no avail. I'm in an isolated site so access to specialized tools is out. I ran it for 15 minutes yesterday morning; tried to start in the afternoon and no-go. All maintenance was completed prior to purchase, and the fuel tank was drained and cleaned.
When running it runs great; the only leaks I can see is comming from the H2O sep, which is more like seepage than a leak, and the return side of injectors 1 and 3.
I've tried RTV on all other fittings but nothing seems to cure it. Could the lift pump be going out?
Old May 19, 2012 | 08:45 AM
RAW's Avatar
RAW
Does it have a block mounted, diaphragm style lift pump? I've changed a lot of those for the same symptoms you are listing.
Old May 19, 2012 | 08:52 AM
CCC1971's Avatar
Yep. Has about 2900 hours on it right now; not sure if its ever been changed. Did you still have pressure comming out of the bleeder on the H20 filter even with that issue?
Old May 20, 2012 | 08:32 AM
RAW's Avatar
RAW
Yes, once primed they work but still pull some air. It looks like that pump had been changed before. Generally the original lift pumps are painted the same add the block, and new ones are unpainted. Is there only one filter on that system?
Old May 20, 2012 | 10:07 AM
Whit's Avatar
Site Mascot
I bet there are 2 filters, one particulant filter and one h2o seperator
Old May 20, 2012 | 11:58 AM
CCC1971's Avatar
Pre filter before the lift pump.
Old May 20, 2012 | 12:00 PM
RanchhandTCR's Avatar
If your sepperator is leaking that your problem I had a Heston 1380DT pulling air thru the sediment bowl, it was leaking and was causing loss of fuel...
Old May 20, 2012 | 01:21 PM
RAW's Avatar
RAW
An inline style, or an actual filter base with replaceable filter? If you do have a replaceable filter style, with a sediment bowl, check for an oring between the filter and sediment bowl. I have seem them missing many times as well. Makes for a very easy service call!
Some Deere equipment and OEM applications don't. I'm not sure why as it doesn't make sense, but they do. SG, SJ series backhoes only have the one, and no inline strainer.
Old May 21, 2012 | 12:37 AM
CCC1971's Avatar
Mine has a sedementer and H20 filter; both housings look original. I sealed all ports on the sedimenter with RTV and do not see any leaks comming from it (new filter/oring verified during acceptance inspection). The H20 housing, however, is cracked and will not allow the lock ring to fully seat; crack was sealed with RTV and threads were cleaned on the housing for the ring. Going to order one today and give it a shot.
The lift pump seems to be putting out great pressure when you pump the handle.
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
robbyS
Apr 16, 2015 02:22 PM
jjmaloney
Feb 18, 2015 04:15 AM
moneypitk5
Feb 12, 2015 11:01 AM
