6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
Clutch help....1994 6.5 5sp Dual Mass? etc
Old May 16, 2012 | 06:17 PM
94turbo-'s Avatar
Default Clutch help....1994 6.5 5sp Dual Mass? etc
OK for the past few days when I push in the clutch, there is a rubbing sound (but not every time) I figure it is the throwout bearing starting to give grief....., and today the tranny was grinding going into reverse. I shut the truck off and put it in reverse and restarted the truck, parked it, then tried it again. everything was OK. Then later I tried it again, and now going into reverse is getting difficult, she grinds.
If I have to pull the tranny and replace the throw-out bearing, pressure plate and the disk, should I look at installing a solid flywheel? How do I know if it has a dual mass without pulling anything first? And is a solid flywheel a direct replacement for the dual mass?
What is the possibility it is the master or slave or both?
1994 6.5L turbo 5sp k2500 142,000 km
I'll reword this, Do I stick with a dual mass flywheel or should I change it to a solid flywheel, and if I change it, is there anything I need to know or change? I will do the pressure plate, disk, throw out bearing, and pilot bearing.
Old Oct 5, 2013 | 04:20 PM
kevinb114's Avatar
the conversion is about 4-500 FOR A SOLID FLYWHEEL Iwould look at your bellhousing there is a grease fitting for your pivot ball it holds your clutch fork on the only way to tell if you have dual mass it has 2 clutch plates. good luck try the grease fitting first
Old Oct 15, 2013 | 11:34 PM
racer55's Avatar
Dual mass flywheels are multi piece flywheels-there is still only 1 clutch disc.
DMF to SMF (Clutch and flywheel) - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Solid flywheel:
http://www.ebay.com/itm/6-5-GM-CHEVROLET-DIESEL-SINGLE-MASS-NEW-FLYWHEEL-/271290577781?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2a2db375&vxp=mtr
Definately get the conversion kit to change from dual mass flywheel to solid flywheel if need be-you don't want the dual mass timebomb anymore if that is what it came with.
Rockauto lists a LUK conversion kit with all the parts to switch from dual mass to solid flywheel-get the part # and order locally or buy from them or see if you can get it from a site sponsor here.
Old Oct 16, 2013 | 09:48 AM
RedChevy44's Avatar
I say go with the solid flywheel, the dual mass flywheels are trouble.
Old Oct 16, 2013 | 06:17 PM
cviola2005's Avatar
^ x2
Jake202
Jun 21, 2015 09:42 PM
smokin91rs
Jun 2, 2015 09:18 AM
5.9sledhead
Price Quote - Request A Price
Apr 23, 2015 09:17 AM
ssmith.77
Jan 11, 2015 02:03 PM
