using a vgt turbo as bottom turbo?
Old May 16, 2012 | 11:28 AM
scottmorgan's Avatar
Default using a vgt turbo as bottom turbo?
i have a 2001.5 ho 5.9 cummins and want to up a vgt 351 turbo off the 6.7's on it if and when i do this could i put another large waistgated turbo on top of it?
and what soes it mean when you post has beem moved??
Old May 16, 2012 | 06:19 PM
RollinCoal99's Avatar
yeah you can make a twin set up with a vgt and a s475 or somthing like that.
Old May 16, 2012 | 10:56 PM
Your post has been moved because you are asking performance related questions in the wrong forum.
It makes work for staff when you post in the wrong forum. We ask that you please take a minute to figure out where your posts should go before posting. Thanks.
Old May 17, 2012 | 12:32 PM
i am new at this.. so i pick dodge and then the years my truck are in and then make a post right? i asked how to put a 6.7 turbo on a 5.9 cummins... that was moved i put it in the dodge 5.9 dodge cummins spot but it gots moved were was i supose to put it?
Old May 17, 2012 | 08:51 PM
wyodiesel92's Avatar
There is a 24v vp standard forum for any non performance orientated questions, basically stock equipment stock parts ect. Performance is for modifications to the engine, trans, drivetrain etc. Since a 351 is not stock equipment and is aftermarket modification it is preferred to be posted in the aftermarket portion of the 24v vp forum.
Old May 17, 2012 | 11:19 PM
Wyodiesel hit the nail right on the head. You are asking about PERFORMANCE modifications on a 98-02 24V Cummins - which is the forum that I moved your post to (this one). Thanks.
Old May 18, 2012 | 12:19 PM
how do i view this performace section i cant find it all i see is dodge then 98.5-2002 and thats all i looked through all the tabs....
Old May 18, 2012 | 03:07 PM
empty wallet's Avatar
It's the "sub forum" and it can be found at the top of the 24v 98.5-02 page, or right off the home page as "24v bombs" the links are right above one another.
But anyways, you can't run a he351 on the bottom it's too small, a 451 maybe, but I personally think a vgt swap is a complete waste of time... total cost vs. benefits just don't really make sense, and building a compound setup off your hy35 would be ridiculous at best. What are your plans and goals for this truck? Fill out your sig so we know what mods you have so far
Old May 18, 2012 | 06:37 PM
i got quadzilla and a high hp clucthc for my 6 speed i have the air dog 150 as well i think that is all i want the instant spool up on the vgt ill spent the money for a larger vgt when the time comes but for now i got stock head bolts and cnt turn more boost just boost sooner!!!
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
