6.7 turbo mods
Old May 15, 2012 | 01:38 AM
CCC1971's Avatar
Default 6.7 turbo mods
Guys,
Comming over from the CF and this is my first posts here.
I have an 08 3500 6.7, auto, 4x4, that I am process of modding (signature will be updated soon, promise). Prior to further mods I'll throw in a set of 625's, AD150 and air flow upgrades to support the turbo mods. I'm completely deleted and running a MM with Overdrive and pyro.
The stock HE351 is not that great, even on unmolested engines; once deleted DP seem to go crazy and gaskets naturally follow. My plan is to upgrade the stocker through Lazar Smith (if offered by them; trying to get word now) or go with a Spectre 64/64/70. I plan on running a set of 60-100 nozzles, since the stock CP with support it. Along with turbo mods I also plan on running a Steed HP manifold with WG tube and a Tial MV-R gate with 11-13# springs. With that out of the way, my questions:
The Tial has two coolant ports; anyone running one of these using those ports, or do you just block them off?
Anyone running either the LS modded unit or Spectre unit? I would like to keep the EB but increase flow. According to DPP, the Spectre units increase flow, while decreasing DP. So far everyone seems to opt for a Silver 66, S475 or Aurora 5000; I want to be different and try to take the VGT tech as far as possible (under 700 HP; not trying to dump 10k into the motor just to support high HP numbers.)
Also looking at LS head prep and coating services; though not needed I would love to have them completely go through my head and get it prepped for higher boost numbers (shooting for 50-60 in the final stages).
Thanks in advance for responses.
Old May 15, 2012 | 03:43 AM
Whargoul's Avatar
Banned
Just swap the 351Ve for a 431Ve or 451Ve.
Old May 15, 2012 | 04:04 AM
CCC1971's Avatar
Been searching for one for days; ebay, craigslist, you name it. So far nada. Do you have a source I may scrounge through? That's the only reason I didn't mention it in the OP. Apparently 451's are difficult to find (at least for me).
Old May 15, 2012 | 04:30 AM
Whargoul's Avatar
Banned
You just have to keep an eye out, they show up every few days/weeks.
NEW TAKEOFF - HOLSET HE451VE TURBOCHARGER - PART NUMBER 3767305 | eBay
Cummins ISX15 Holset HE451Ve VGT Turbocharger Turbo | eBay
NEW TURBOCHARGER HOLSET CUMMINS HE451VE VGT 2843481 3767305N ISX ENGINE | eBay
You can also buy them straight from Cummins if you're willing to spend $3-5K.
Just remember that some of the newer ones, especially from the ISL engines, have choke ring cast into the turbine housing outlet. You'll have to grind/machine that out to get the best flow.
Old May 15, 2012 | 05:43 AM
CCC1971's Avatar
For about $2,400 I can get a 64/64/70 with billet wheel or a 64/67/70 for another $200. The 64/64 doesn't require fueling mods, but resonds well to the airflow improvements I have planned, and will also work well in a compound setup if I ever go that route.
No-one is using a Tial WG? Seems as if the Pro Gate is popular, but want to use the Steed manifold.
Old May 15, 2012 | 06:08 AM
Whargoul's Avatar
Banned
Then you're stuck with a laggy non-VGT turbo.
Old May 15, 2012 | 07:03 AM
CCC1971's Avatar
Spectre VGT
Diesel Power Products Spectre VGT Turbos 2007.5-11 Dodge Ram 6.7L Cummins
Old May 15, 2012 | 08:09 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i really like the vgt design but have sold a few 66 silver bullets. man they are nice. if guys dont do inj i tell them 64s.
Old May 15, 2012 | 06:45 PM
coors_man_2005's Avatar
im running sb66 on stock injectors right now. i tow 20k its pretty good close to stock spool time. i love the turbo with my current setup. but im fixing to go too 100hp injectors and stage 3 water meth. later i will prolly compound with s480 or s483
Old May 16, 2012 | 05:46 AM
CCC1971's Avatar
Coors,
How was Lazar Smith to work with? Their website is like a Christmas wishlist everytime I check it out.
