crank pulley rattle
Old May 14, 2012 | 05:53 PM
Slim Whitey's Avatar
Default crank pulley rattle
So the 6.5 developed an odd intermittent rattle here a few weeks back.
I assumed it was a pulley of some sort and have since pulled th ebelt and checked em all.
and it'd seem there is issues in the crank pulley or harmonic balancer. i can take and turn the crank pulley about 1/8th of a turn before I hear a metal on metal sound and it stops.
Wondering if it's the pulley itself, or it the balancer is fucked.
I'm hoping its the pulley, I don't wanna try a balancer replacement.
Old May 14, 2012 | 06:07 PM
wolf1365's Avatar
most likely its the pulley if u have the rubber insert kind, but if it the ballancer replace it quick it can cause a -hit load of more problems.
Old May 14, 2012 | 06:40 PM
I dunno what kind I have. 95, S vin engine.
just crawled under and checked.
there is a large rubber ring on the inside backside of the pulley that i can see, and that rubber is cracked/shot at the very least.
the balancer action is smooth, there isn't a real wobble there (not that you need much of one at 2,000rpm and 22:1 compression). I don't see much damage to the rubber on the balancer that i can tell either, but that is while I'm on my back looking up at it, so I won't say it's a perfect look.
from what I can see the pulley is 4 bolts off the front side and it should slide off. is it really that easy? nothing on this frickin engine is that easy.
you'd think after helicoiling the starter bolts when they stripped right out of the block, a simple pulley swap wouldn't be foreign to me. . .
Old May 14, 2012 | 07:47 PM
wolf1365's Avatar
four bolts and a little Persuasion its off and bet u will find its got a broke rubber, and while your under there check the balancer rubber real good, they are known to come loose.
Old May 14, 2012 | 11:24 PM
K will do.
hopefully it can wait the 2 weeks till I get paid. kinda busted right now. as in...proper busted.
ish1521
Aug 26, 2015 08:42 PM
Mr. Walkway
May 11, 2015 10:49 AM
nomoney
Apr 12, 2015 06:14 PM
6btf350cummins
Dec 16, 2014 07:23 AM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
