Replacement for air pump
Old May 12, 2012 | 05:51 PM
wolf1365's Avatar
Default Replacement for air pump
Where can I get a idler pulley to replace my air pump assembly, been looking with no luck.
Old May 14, 2012 | 10:22 AM
ebarresi5894's Avatar
by air pump do you mean vaccum pump?
Old May 14, 2012 | 05:46 PM
wolf1365's Avatar
yeah vacuum air device for providing suction to the waste gate. that's the one..
Old May 15, 2012 | 10:34 PM
i would check a bone yard for cheap, or SSDiesel Supply :: GM 6.5 TD Specialists, PMD failure, FSD heat sync kit.
Old May 15, 2012 | 11:14 PM
Jeff Bennett's Avatar
Why does my 93 6.5 not have a pulley operated vacuum pump?
Old May 16, 2012 | 06:50 AM
because it has a mechanically actuated waste gate. it has a spring and adjuster, way less simple and way better than the vaccum system
Old May 19, 2012 | 02:21 AM
cviola2005's Avatar
so the mechanical wastegate actuator is adjustable? how is it adjusted?
Old May 19, 2012 | 11:06 AM
i believe there is a nut on the end of the rod.
its almost like a turbo master, but dont quote me yet ill do a little research
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HeavyChevy95
Dec 21, 2016 10:36 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
moneypitk5
Feb 12, 2015 11:01 AM
