idle high
Old May 12, 2012 | 04:59 PM
ducktape's Avatar
Default idle high
so im at around 900-950 idle at OT. the idle screw is all the way down cant turn it any farther..... how do i get it lower?
97 12v 5spd
Old May 21, 2012 | 03:10 AM
leakin 12 valve's Avatar
have you checked to see if any of the cables are stuck. you should be able to force the arm that the gas pedal moves, back to a lower idle. one more suggestion try turning it the other way.
Old May 21, 2012 | 09:18 AM
You may have messed something up with the cable when adjusting the idle. check things over something isnt right.
john grossman
10
Jan 12, 2019 08:58 PM
robbyS
Apr 16, 2015 02:22 PM
CumminsCoalRoller24/7
Feb 21, 2015 10:44 PM
robbyS
13
Dec 20, 2014 04:25 PM
jmerriman17
Nov 21, 2014 04:38 PM
