fueling issue
Old May 11, 2012 | 09:06 PM
wyodiesel92's Avatar
Default fueling issue
Well my airdog doesnt seem to be holding pressure well, cold temps itll idle at 19 to 20 and driving go down to 16 with minimal pedal, hot 16 to 17 idling 14 cruising and dropping to 11 wot. Also my pressures dont stay very steady, the sender is 6 inches from the vp. Doesnt seem to suck air just isnt keeping up amd seems like it might be by passing.
Another issue is i seem to be getting some slight hiccups while at wot. Not sure if maybe the vp or the airdog could be to blame for both or just separate issues.
Filters on the airdog only have 6000 on them also.
Old May 12, 2012 | 10:45 PM
Bump
Old May 14, 2012 | 08:35 PM
Bump
Old May 14, 2012 | 10:31 PM
cummins270's Avatar
What gph is the pump rated and do you have a tuner or injectors?
Old May 15, 2012 | 12:17 AM
Its in my sig....airdog 2 165gph, edge juice w att no injectors.
Never had this problem when i ran a raptor on my old truck. Starting to hate this airdog
Old May 15, 2012 | 12:58 PM
cummins270's Avatar
Sorry I'm using my phone and it doesn't show Sig... But that 165 should keep up better than that I would think. My raptor falls the same psi as your pump does and its only 100 gph but it started to do the same thing yours did so I got a 200 gph pump now. I would try changing the filters it helped mine a lot when I did.
Diesel_Daddy6.0
Sep 23, 2015 03:12 AM
JKinni
13
Sep 5, 2015 11:09 PM
big tan snorkel
15
Dec 17, 2014 05:04 PM
norcal6.5
Dec 7, 2014 07:04 PM
Oct 23, 2014 08:10 AM
