86 6.9 crank ...no start
Old May 10, 2012 | 06:30 PM
rapidroy5858's Avatar
Default 86 6.9 crank ...no start
Went to start my f250 today but it will not fire, it has great fuel pressure all the way to the pump ,it will fire on ether, I did not have time to check for fuel at Inj, lines this morning but I will tonight,if I have no fuel from pump to injectors is it reasonable to suspect the fuel solenoid that turns the fuel on and off, I am not very familier with the system on these idi's but just seems logical ...short of a pump that has gone bad....should both wires at the solenoid power up with key on? Thanks in advance
also...New batts, glow plugs working, no fuel leaks...thanks again
Old May 10, 2012 | 07:10 PM
7.3 idi 1990's Avatar
Timing advance, on the back, and fuel shut off on the front, and yes they are to have power on them when key is on.
Old May 10, 2012 | 08:43 PM
ok thanks will check for power tonight, if it is powered I guess I'll have to start checking the ip?
Old May 10, 2012 | 08:46 PM
Default reply
Fuel lift pump, or lines from tanks on up to it
ish1521
Aug 26, 2015 08:42 PM
tmcc14
Apr 21, 2015 03:59 PM
ebg2g
Mar 29, 2015 06:15 PM
musikagod
11
Nov 30, 2014 07:22 AM
murderedf250
Oct 15, 2014 04:26 PM
