Removing Edge EZ from a 2006 Cummins?
Old May 7, 2012 | 09:32 PM
Mr.CityWide's Avatar
Question Removing Edge EZ from a 2006 Cummins?
Truck in my sig is the one in question. Searched their website and didnt see any details on exactly how to return to stock. The reason i want to remove it is my check engine light is on and code reader says "link error". Also when i try to start the truck, everything powers up like normal but does nothing when i turn the key and the gear indicator is completely gone. Truck has 130,000miles. Thanks in advance
Just saw that i shoulda posted this in the Performance section, sorry
Old May 8, 2012 | 10:06 AM
Bump
Any help would be greatly appreciated?
Sent from my DROID2 GLOBAL using Tapatalk
Old May 8, 2012 | 11:53 AM
RAW's Avatar
RAW
It should just disconnect at the fuel pressure sensor and MAP sensor. Remove the Edge Y connector, and plug the factory harness back into the sensor.
http://www.edgeproducts.com/product_...manual-157.pdf
Page 10 shows where the connections are. After disconnected, it's just a matter of physically removing the harness and module.
Old May 8, 2012 | 12:15 PM
So there's nothing else that needs to be done other than physically remove the harness? I just want to make sure before I do it in case there are some other steps that need to be taken. Also from what I've been reading, the problem I'm having with it not starting or cranking is adjusting the cable from underneath the steering column?
Sent from my PC36100 using Tapatalk
Old May 8, 2012 | 12:28 PM
CHEMMINS's Avatar
Nope, thats all ya do is remove the unit....I just took mine out 2 days ago.
Old May 8, 2012 | 09:23 PM
Default p0194
Ok so when i had the truck in diagnostic mode the code it displayed was 0194. Thw truck wont start. What should i do next? Also after you display the codes on the odometer, will it not display again? After it displayed once it wont show up again, just get -------- then done
Old May 11, 2012 | 11:47 PM
Question EDIT: P0193
So i misread the numbers like a moron. The code p0193 and the truck wont crank. What are some possible causes/solutions? Oh and the tranny leak is a cracked OD housing, thinking about buying a housing and doing it myself, Anyone else done thats done this have any tips/tricks or know where i can get a reasonably priced housing?
RexShoppe
Price Quote - Request A Price
Nov 23, 2015 02:38 PM
nathanmueller
Diesel Engine Conversions
Sep 8, 2015 03:30 PM
regitan
Big Rigs & Semis
May 24, 2015 10:23 PM
Ram700
Jan 2, 2015 08:14 PM
Sbboozer
Nov 16, 2014 05:52 PM
