t/c lockup switch. bad or good?
Old May 7, 2012 | 07:26 AM
SRTcummins's Avatar
Default t/c lockup switch. bad or good?
I was planning on getting a lock up switch on my truck. I wasn't going to use it to smash through the gears but to use it for my overdrive because my t/c unlocks when the turbo spools past 7 lbs. My trans has been good to me so far i just don't like the power loss when it unlocks.
Thanks
-nick
Old May 7, 2012 | 08:22 AM
RAW's Avatar
RAW
That's very odd that it unlocks at 7psi. It should be locked all the time in O/D, and at higher speeds in 3rd. Installing a switch would be a good way to test to see if the t/c lock up is working or not. Only downfall I see to the lock up switch is not remembering it while slowing down.
Old May 7, 2012 | 09:47 AM
SRTcummins's Avatar
well its not like right at 7psi, its just when i give her a good amount of gas like 20% maybe in low rpm and like 30% at like 1700. but i didnt even think about testing it. ill post a video of it unlocking...and also when i press the brake when it is locked in O/D or 3rd gear it unlocks as well could the problems be related?
Old May 7, 2012 | 10:37 AM
RAW's Avatar
RAW
It is supposed to do that. Pressing the brake will unlock the T/C, it is also a good test.
Old May 7, 2012 | 11:33 AM
SRTcummins's Avatar
Well when my T/C unlocks very easily and it is hard to accelerate and ifeel like it damages the T/C when it is unlocked and just spinning to the point where it can without slipping.
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Freezzman
Jul 6, 2015 03:01 PM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
IslanderXJ
Dec 17, 2014 04:14 PM
