crank no start, no wait to start light
Old May 3, 2012 | 08:37 AM
wilke12V's Avatar
Default crank no start, no wait to start light
dads truck has been sitting for a week now. i got to jump in it and turn the key on and there was no wait to start light, tried to start it anyway and all it did was turn over...havnt had time yet to put it on a scanner yet...everything else on the dash works fine. any help would be great so i have a starting point. thanks in advance
sorry its a 2001 stock but the ts-6pos. started right up last week, now this out of no where
Old May 3, 2012 | 09:39 AM
95powersmoker's Avatar
check all the fuses...
Old May 3, 2012 | 05:17 PM
wilke12V's Avatar
Ok well i was messing with it today. And i kinda put the key at an angle and the wts light flashed on then off cycled the key at an angle a few times and the light came on as normal tried to start it and it popped right off......Idk ignition cylinder?
Old May 19, 2012 | 06:52 PM
homerj's Avatar
I had a similar issue just a few weeks ago that ended up being the connection between the battery posts and the cable terminals. Cleaned up both with a wire brush and all was OK. Worth a shot before you go down that rabbit hole. DAMHIK
Old May 20, 2012 | 06:45 PM
fordornothing's Avatar
check fuse no. 30. that's PCM power and WTS and tach. if it's blown, unplug the fues bowl heater.
schwier94
Sep 26, 2016 09:07 AM
ish1521
Aug 26, 2015 08:42 PM
bullrideris1
Jan 23, 2015 09:22 AM
musikagod
11
Nov 30, 2014 07:22 AM
NCC74656
Nov 4, 2014 10:46 AM
