Exhaust Routing
Old May 2, 2012 | 10:41 PM
texfrost's Avatar
Default Exhaust Routing
I took my tailpipe off last winter, post muffler. While replacing my front axles and greasing driveshaft ujoints, I noticed two things. One, that the pipe came loose from the front of the muffler as well, and two, how much soot was on my drive shaft.
I left everything alone because, frankly I like the way my truck sounds right now and I didn't want to alter tha, but now with the soot buildup, I figure its time to do something. I just don't know what I can do in order to keep the tone I have right now.
I also want to be able to mount a secondary tank on the RH underside, so that means I can run it strait down the bedside.
Any suggestions? I thought about running it down the drive shaft but I figured that might add too much back pressure due to the extra bends. If I went to a 6inch cat back, would that solve the pressure issue that might arise from the two extra bends?
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
