97 ford f350 crank but no start.
Old May 2, 2012 | 02:10 PM
Oklahoma diesel's Avatar
Default 97 ford f350 crank but no start.
I am working on a buddies truck it's a 97 350 drw auto. Checked the hpop desk our and it was empty, filled it up and still wouldn't start, hooked up his programmer to see what codes where present and it showed cam sensor, and injector voltage to high/low. Pulled the valve covers all the wires look good, but their is no oil dumping from the injectors while cranking. Cracked the high pressure oil line and not much oil came out. The resivor was still full of oil, has fuel coming out of the shredder valve. I checked the oil in the crank case and found big metal shavings on the dip stick every time I checked the oil, any one ever come across this issue? Truck also has 285xxx miles.
Also changed the cam sensor
Last edited by Oklahoma diesel; May 2, 2012 at 02:10 PM. Reason: Automerged Doublepost
Old May 3, 2012 | 10:14 AM
95powersmoker's Avatar
well first, big metal shavings in the pan is not a good thing.....
secondly, where did you get the cam sensor?
Old May 3, 2012 | 11:51 AM
Cam sensor came from autozone, the tack works now though.
Sep 15, 2015 07:40 AM
ish1521
Aug 26, 2015 08:42 PM
88 f350 7.3 idi
Aug 20, 2015 09:18 AM
