New truck, checking my build idea
Old Apr 28, 2012 | 01:07 PM
Redneck2's Avatar
Default New truck, checking my build idea
I just picked up a 93 W250, 5-speed and am planning my build. Its a daily driver that does some towing. Although I want power, I want low end, quick spooling off the line torque. Screw high hp dyno pulls, this is a VE pump. Im planning on an exhaust manifold and a super b type, or a 62/65/12, that will eventualy be part of a set of twins. Injectors, I was thinking of the CPP 7x.010's. Then the typical pump tuning, a 366 spring, M&H #3 fuel pin and dynamic timing advance. Then a 4 or 5 inch straight exhaust. Would this be a good combo? Any advice? Oh yea, gauges are a given, and will be on before any mods.
After the first of the year, I will be going to twins, PS intercooler, NV5600 swap, cam, headstuds, o-ring & work head, whatever else I can figure out.
Old Apr 28, 2012 | 05:16 PM
turbo2332's Avatar
may want bigger sticks if you are planning for twins 7x.010's would be great for the superb or 62/65/12
Old Apr 28, 2012 | 06:35 PM
Redneck2's Avatar
What would you recomend that would not be too much for the single, but would be more appropriate for the twins? 7x.012?
Old Apr 28, 2012 | 07:02 PM
turbo2332's Avatar
7x.010's will work but you will want more. 5x.012's work well with my super B but with twins i would want 5x.014's
Old Apr 28, 2012 | 07:07 PM
Redneck2's Avatar
Dont the 7 hole injectors work better on the low end? I think I want to stick with a 7 hole if I can. Isnt a 7x.012 going to flow alot more fuel than a 5x.012?
Old Apr 28, 2012 | 07:15 PM
turbo2332's Avatar
ya too much...
a 7x.01 is small than a 5x.012
and i havent really heard any conclusive data about 7 hole being any better. everyone i know runs 5 hole from street trucks to pullers.
Old Apr 28, 2012 | 07:54 PM
Redneck2's Avatar
Then I will have to look at a 7x.011. I have talked to a couple people who run them and they all claim slightly quicker spooling and right off idle grunt. Even if its miniscule, any little down low, I want. I havent heard of any problems or I might look into 5 hole.
I forgot to mention, but I do plan to do a low pressure piston lift pump swap.
Old Apr 28, 2012 | 08:13 PM
welderboy250's Avatar
I'm not a fan of CPP especially for injectors. Have had some problems with quality control issues, on time shipment of product, as well as general communication and customer service. I know some people receive good service from Jamie but he dos not seem to be the most reliable source for injectors.
Old Apr 28, 2012 | 08:18 PM
Redneck2's Avatar
Well, the SDX's are my second choice, but Ive heard they are usualy backordered all to hell too.
Old Apr 28, 2012 | 08:22 PM
turbo2332's Avatar
thats what i run and have nothing but good to say about them
