should i change up the chip
Old Apr 24, 2012 | 08:20 AM
Adam Fonda's Avatar
Default should i change up the chip
I've got a 03 lb7 wit a bullydog 3 stage chip.... full exaust an intake an meth injection was tryin to see what else i could do with out either worryin about the headbolts or torckinverter slipping I keep herein from some of the guys around that have duramax's I'm gonna have problems if I keep adding more on to the truck gm Jus had.to put a new pump an injectors in las month for free
Old May 1, 2012 | 09:59 AM
1AMatt's Avatar
Site Sponsor - 1aauto
If you get another chip you will most likely limp the trans Before you go too crazy you may want to think about doin some work to it!
Old May 1, 2012 | 04:29 PM
2004LB7's Avatar
^^ exactly
5 speed Allison will only take about 60 or so HP over stock before it starts to slip. upgrade your transmission before going any higher in HP first.
Old May 19, 2012 | 04:41 PM
GSE-DMAX's Avatar
Originally Posted by 2004LB7
^^ exactly
When You say 5 speed allison do you mean the automatic allison 1000 thats in the 04?
Old May 20, 2012 | 04:17 AM
2004LB7's Avatar
yes. the Allison 5 speed is in 01 to 04.5. above that it is the Allison 6 speed automatic
the ZF6 manual was also a 6 speed made by ZF in Germany, used on some of the earlier years. a rare bird indeed. too bad GM doesn't provide it anymore.
Old May 21, 2012 | 12:48 PM
BriteWhiteRam's Avatar
The ZF6 was available from factory from 01-06, however it is very rare to find one with it equipped
Yes you need to upgrade your transmission if you plan on adding more power to your 03
Would you care to tell us how you got your injectors and CP3 replaced for FREE from GM?
wlofton
11
Jun 26, 2018 08:58 AM
ctjkelley
Jun 3, 2015 06:01 AM
crusty
5.9L CR Performance
Apr 26, 2015 03:31 PM
Dieselhead1052
Nov 26, 2014 05:43 PM
corey352
10
Nov 20, 2014 08:04 AM
