BD stealth cover question!
Old Apr 23, 2012 | 12:04 PM
SRTcummins's Avatar
Default BD stealth cover question!
Hello everyone,
So my BD stealth cover was put on and I showing my dad what was done to my truck and he pointed out that the red wire on the cover was disconnected. I was like huh so I checked were that wire went to and it went to the tap wire of my edge box, but I still have power from my chip which boggles my mind I talked to thorough bred and they couldnt help me.
If anybody knows what this wire does and If i dont have it connected what will happen i would appreciate it!
^^ thats the main question!
Thanks
-nick
Old Apr 23, 2012 | 03:37 PM
Blair@BD's Avatar
FormerVendor
the wire was to attach to your edge box.
Old Apr 23, 2012 | 03:53 PM
RAW's Avatar
RAW
Yep, that wire is supposed to be connected to the "pump tap" are from your Edge.
Old Apr 23, 2012 | 06:23 PM
SRTcummins's Avatar
ok well i connected it and no difference my vp44 may be blowing smoke without the chip
Old Apr 23, 2012 | 06:38 PM
RAW's Avatar
RAW
Was you pump tapped already, and you just moved it from the wires on the back to the stealth plate pigtail?
Old Apr 24, 2012 | 09:40 AM
SRTcummins's Avatar
i got the vp44 with the cover, both brand new. i had hallas performance(if anybody has heard of them) put it on. they didnt tap the wire they used the stealth cover instead.
Old Apr 24, 2012 | 09:45 AM
RAW's Avatar
RAW
So they installed the cover, but the wire from the EJWA fell off, or did they not connect it?
There is no noticeable difference with the wire now connected?
Old Apr 24, 2012 | 04:20 PM
SRTcummins's Avatar
Well the tiny 6 sided nut was missing luckily i found another and put that one on but i did not noticed a difference. i cycled through all the settings and setting number 1 would make my trans slip all the others i would just flutter a bit, i could notice the power increases as well as the smoke.
Old Apr 25, 2012 | 12:41 AM
RAW's Avatar
RAW
Have you tested the connection at the Stealth cover pin? If not have a look at this thread:
https://www.dieselbombers.com/5-9l-2...e-install.html
quiksilver1j
Jul 30, 2015 12:41 PM
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
carid
Group Buy
Mar 27, 2015 07:31 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Ryans71
Jan 14, 2015 07:52 PM
