pinned fuel pressure gauge
Old Apr 23, 2012 | 09:17 AM
jigga747de's Avatar
Default pinned fuel pressure gauge
would anyone know why my fuel pressure gauge would be pinned at 30psi at idle? Normally its between 15 to 20psi at idle and when your in the pedal it goes down to normal but let off, back to 30psi. if it helps it has a stock lift pump with 20k on it
Old Apr 23, 2012 | 06:41 PM
empty wallet's Avatar
normally those spikes are caused by clogged fuel filter or some serious restriction somewhere else
Old Apr 23, 2012 | 06:56 PM
RAW's Avatar
RAW
Pressure regulator stuck in the return fitting, perhaps.
Old Apr 23, 2012 | 09:53 PM
Verify with another pressure guage (mechanical)...bypass the isolator if you are using one
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Jan 24, 2015 10:55 AM
