96 stroke craigslist chip
Picked this chip up on Craigalist. Torq-line Power Chip it says TPC-9701 1997 Ford F250,F350.......Ok so I have a 96 stroke, I thought hey 94.5-97 all the same...Plugged it in...turn key...my wait to start light does not come on.....Engine just turns over never starting.....Unplug chip everything goes back to normal,truck is fine....Is this chip that smart only to work on a 97 truck?????? please help
Does the chip attach to the PCM? Did you clean the PCM contacts?
If you cleaned the contacts on the PCM, then it's because the trucks have different PCM codes and you would need to find someone who can tune that chip to work with your pcm...
When i bought my ts i didnt get the one for the cali model truck and it did this same thing... maybe its for a cali truck? or maybe its for a stick and you have an auto? vise versa
Exactly. Either way, that's a pcm issue and requires a reburn. The issue here is finding a tuner who can do it with his chip...
Dec 10, 2014 08:10 AM
Oct 13, 2014 08:10 AM
