Head bolts and gaskets?
Old Apr 13, 2012 | 02:42 PM
er318's Avatar
Default Head bolts and gaskets?
What head bolts and gaskets should I put on my 6.5td and where can I buy them
Old Apr 13, 2012 | 03:01 PM
great white's Avatar
Head bolts are torque to yield and one time use only. Factory replacements will do. Get an angle gauge so they can be installed correctly.
You can go with ARB studs, but you can't get the heads on and off the block with it in the truck. You have to install the front studs, then lay the head on and finally thread the rear studs in. Then torque the whole shmozzle down to spec. If you ever have to remove the heads, you'll have to reverse the whole process.
Some of the bolt holes go into the water jacket and studs have been known to leak. A sealant on the threads my take care of that, but there's no guarantees...and then you have to pull the heads back off, which means reversing hte stud installation procedure....
If you're just fixing a popped head gasket, just get new TTY bolts and forget the studs.
For gaskets it's hard to beat a good set of new felpro's.....
Old Apr 13, 2012 | 04:35 PM
ebarresi5894's Avatar
fel-pro everything, any auto parts store should be able to get them, it came to like 80-90 for both head gaskets and bolts on my truck.
2500HeavyDuty
Chevy/GMC Duramax 01-04 LB7
238
Dec 6, 2017 05:16 PM
Hardcorefx4
Oct 6, 2014 07:47 PM
