94 fummins project looking for some info>
Old Apr 9, 2012 | 09:13 PM
TOM81650's Avatar
Default 94 fummins project looking for some info>
I have a 94 f-250 7.3 non powerstroke turd and i have a 6BT industrial engine does anyone know if i can use this engine in the truck or do i need an engine out of a truck and what all i may need to do to it to make it work any help will be much appreciated.... thanks
Old Apr 10, 2012 | 08:31 AM
93_Fummins's Avatar
A little more detail please...? What kind of "industrial" motor? Are you curious if it will work or if it will be "road legal" according to the smog police? You'll definitely need to hit the aftermarket or pillage a few donor trucks for parts assuming that the "industrial engine" you speak of probably does not have a bellhousing/adapter plate for your or a comperable pickup transmission....among other bits and pieces to make an easy swap
Old Apr 10, 2012 | 08:55 AM
TOM81650's Avatar
We don't have smog police so I'm not worried about that I'm pretty sure it's out of a log skidder the I'd plate says 6bt 1987 I have a 93 dodge sittin around that has everything except the engines spoken for but I can have bellhousing and odds and end from it the main thing I'm worried about is an oil fill where I'm pretty sure the driver engine mount goes. I appreciate the help
Old Apr 10, 2012 | 01:39 PM
prowler48's Avatar
I'm putting a 6bt out of a '94 school bus in my 1997. I got motor mounts from ford cummins and they cleared the oil fill tube that your talking about.
i guess its not really an oil fill tube on mine though. the oil on the '94 is filled through the timing but there is a line that the dip stick runs down to the pan that is close to the motor mounts. my mounts cleared it.
Old Apr 10, 2012 | 01:48 PM
RanchhandTCR's Avatar
Your should be ok but industrial motors depending on the application are govened at 1500-1800 RPM so you are gonna want to change that so it can be governed at 3200 RPM.
Old Apr 10, 2012 | 05:01 PM
TOM81650's Avatar
Thanks guys Im trying to get a pic up of the oil fill I was talking about but it won't let me on my phone. Another question will the bellhousing for an automatic 24 valve work with the adapter to my zf 5 speed?
Old Apr 13, 2012 | 07:39 PM
TOM81650's Avatar
i cant get to it to get a pic but the oilfill im talking about is about 1.5 inches and its in the middle of the four driverside motor mount bolts im just wondering if im gonna have to get it welded up and move it or what do you guys think
Mar 4, 2015 08:20 AM
Nov 16, 2014 05:14 AM
Nov 11, 2014 04:10 PM
