Hard time starting
Old Apr 6, 2012 | 03:58 PM
zbructo's Avatar
Default Hard time starting
I have 01 and has been acting wierd in mornings starting up. It's done this now four times in the last year it happened twice this week though. Go to start it up in morning fires up then shuts down right after. Then cranks over but wont start. Got it to fire up the other day after jump starting it but didn't seem to want to fire up forever when jump starting it off father in laws truck. Checked fuel filter connections since changed it just recently think it could be something fuel related? Checked didn't see any fuel leaks when primed it.
Did prime the fuel and started up shortly after. So going to change the rings out on filter and see if thats maybe causing air to slip in.
Old Apr 8, 2012 | 05:12 PM
cfarley0210's Avatar
I had similar problems. I got a rebuild kit for the filter housing and a new wif sensor and the aluminum bleed screw and it has been working good ever since.
Old Apr 9, 2012 | 12:39 AM
2004LB7's Avatar
^^ those darn bleed screws. i got by for a while with Teflon tape on mine
Old Apr 16, 2012 | 05:21 PM
zbructo's Avatar
Thats what im trying right now ordered a bleed screw and wif sensor. Now my check engine lights on saying i have high rail pressure.
Old Apr 16, 2012 | 06:55 PM
2004LB7's Avatar
ether fuel pressure sensor (connection/wire loose or broken will make it read max psi) or CP3 regulator valve (FPRV) sticking, burned, or otherwise not working right
what codes have you got?
Old Apr 20, 2012 | 04:04 PM
zbructo's Avatar
Was the bleeder screw. Screw was stripped good. Ordered metal one online installed it and has ran good now.Seen on here few times what people write in for the problem but not give the final piece of the puzzle. Figured I'd show the answer to my problem. Thanks for the suggestions.
Old Apr 20, 2012 | 04:09 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
Excursion73
Oct 27, 2015 05:21 PM
Easton18t
Jul 30, 2015 02:06 PM
joker55
May 15, 2015 10:24 AM
gwmeyer
May 14, 2015 12:46 PM
91 7three
Jan 7, 2015 09:37 AM
