Ford Excursion 99-05 7.3L and 6.0L All Discussion on the Ford Excursion with 7.3L and 6.0L Power Stroke V8 Turbo Diesel Engine. Including Bombs (Aftermarket)
steering pump/hydro boost KAPUT!
Old Apr 5, 2012 | 06:53 PM
olbattlebuggy's Avatar
Default steering pump/hydro boost KAPUT!
I have a 2004 limited EX with PSD. I have recently developed a weak steering assist from my power steering and a soft break pedal on breaking. No leaks from breaks or steering. what the heck is up? what should or could i do do narrow or diagnose what is busted. Steering fluid is at proper level...
Old Apr 10, 2012 | 02:18 AM
CSIPSD's Avatar
More then likely the pump is getting weak... You can try replacing the fluid, and when you do replace some of it (one or two qts) with Lucas Power steering stop leak... Works like a charm!
Old Apr 23, 2012 | 12:40 PM
BKID's Avatar
Yes this is what I did and now there is no problems.
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
ash23k
Dec 30, 2014 08:31 PM
sweetv8s10
Oct 7, 2014 09:47 PM
