any luck with ebay intercoolers?
Old Apr 2, 2012 | 10:40 PM
pullincrazy88's Avatar
Default any luck with ebay intercoolers?
Is anyone running an aftermarket intercooler with there cummins swap. I reason I ask is I could probably find one cheaper then an original one or say a fords 7.3 intercooler to use. I'm not talking a $1500 dollar one. just a generic ebay one.
Old Apr 2, 2012 | 11:33 PM
H.R.D's Avatar
Post the one you are looking at and lets us take a look at it.
Old Apr 3, 2012 | 07:54 AM
deck60's Avatar
when I was intercooler shopping I bought one from my local junk yard for 60.00 if my memory is right don't know if it was a 6.0 or a 7.3 told him what i needed and he had one for me the next day
Old Apr 3, 2012 | 08:36 AM
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices probably not that exact one but they all seem to say there rated for 60psi max and 600-800hp but i believe that's for a gas engine. thats the bad thing around here there really isn't any junkyards that have any dodge or fords in them that were diesels. so i cant rob an intercooler out of one.
This would also let me get one to fit a little better in the space i have.
correction it says nothing about max boost pressure just about working pressure
Last edited by pullincrazy88; Apr 3, 2012 at 08:36 AM. Reason: Automerged Doublepost
Old Apr 3, 2012 | 09:04 AM
deck60's Avatar
ok I looked at it and I think it is too small the one I have is a little over 3" inlet and outlet
do this I looked where you are at go to car-part.com there are several not to far away from you I bet for about the same price as what you are looking for there
rhine auto has several for 135 out of 05 ex with a 6.0 1-800-535-2325
Captain Todd's Wrecked Cars, Inc has one for a 7.3 for 125 1-800-252-1079
Old Apr 3, 2012 | 09:08 AM
i just used that one as an example i would be getting a larger one then that. but i will look into those thanks
Old Apr 3, 2012 | 09:42 AM
deck60's Avatar
what are you putting it in
i found it
gm 3500 right ok here is what i found for you some time stock stuff work better better mounting radiators and intercoolers
Elmers Auto Salvage 165.00 for a 3500 1-800-362-5004
Old Apr 3, 2012 | 01:31 PM
ummmm elmers auto salvage is over 5 hours from me and i plan on using my stock radiator that is in the truck. its a 4 core that came factory with my big block. should have no problem keeping the cummins cool
im also not to worried about mouning as im going to have to make the brackets anyways and probably cut out part of the core support and modify it theres barley any room behind the grill. i would trust a stock one more then an aftermarket that no one has ever used but if i cant find one close to me cheap then my alternative is some kind of an after market one for cheap
Last edited by pullincrazy88; Apr 3, 2012 at 01:31 PM. Reason: Automerged Doublepost
Old Apr 3, 2012 | 02:12 PM
deck60's Avatar
stock is the way to go I would call them and see what it would cost to ship it by speedee
I use them all the time will probably be under 25.00
Spee-Dee Delivery Service, Inc.
Old Apr 5, 2012 | 11:07 PM
crewcab59's Avatar
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices I believe this is the one i used....same dimension except with 2 1/2 inlets and my egt's are in check
