Duramax or other for my swap.
Old Apr 1, 2012 | 11:32 PM
curtis73's Avatar
Default Duramax or other for my swap.
I have a 66 Bonneville that has gone through many iterations. Right now it has a 10.5" FF rear and 3/4 ton front spindles and brakes. Last drivetrain it had was a Caddy 500/TH400/GVOD. I'm going diesel with it.
Obvious answer is Duramax since it will be the easiest fit, but I'm not against other ideas. Cummins is WAY too tall. Powerstroke 6.0 or 6.4 will fit with a good bit of cut and paste.
I thought very hard about the VW V10 TDI, but its not exactly cheap nor do I know its true reliability. Same goes for Bluetec.
Goals are a modest 450-ish hp with easy parts availability in case of breakdowns. There should also be an emphasis on smoothness. Its a luxo land-yacht, not a 4x4.
Am I missing anything obvious? The Dmax would be easy, but I don't want to decide on it before looking at all the options I can think of.
Attached Thumbnails Duramax or other for my swap.-outandabout.jpg   Duramax or other for my swap.-8-lugz.jpg
Old Apr 2, 2012 | 12:50 AM
2004LB7's Avatar
Duramax
450 HP should be plenty for it
Old Apr 4, 2012 | 04:42 PM
curtis73's Avatar
Originally Posted by 2004LB7
Duramax
that's what I was thinking too... just didn't want to miss anything obvious.
Old Apr 4, 2012 | 04:54 PM
2004LB7's Avatar
you could check up on the EFI Live forums as well, as some are very educated on getting the duramax running good in other chassis. "THEFERMANATOR" is one i can think of
Old Apr 4, 2012 | 10:42 PM
DieselS10's Avatar
I managed to get the Duramax running in mine and was in completely over my head. You can get it done. For me it was easiest to just use the complete Duramax underhood and in cab harness with the cluster, steering column, bcm, fuse blocks, etc.
Jul 28, 2015 12:40 PM
jt19
Jul 13, 2015 03:06 PM
hisrized
Show And Tell
Mar 15, 2015 12:06 AM
ReckONE
Feb 25, 2015 09:41 AM
duramaxtuner
Dec 10, 2014 01:24 PM
