does a 97 ford f350 powerstroke have lift pump
okay i just want to now if my 97 ford f350 powerstroke have a lift pump. and if i add more horse power if i need to put in a aftermarket fuel system
they have a mechanical transferpump that sits in the valley of the motor. and no u wouldn't need to put a different fuel system if you add more power to it. the only thing is depending with injectors is an upgraded hpop
Easy there... Not exactly 100% correct. The fuel system will need upgrading at a certain point as well as the HPOP... The factory fuel system pressures bounce around like crazy and at WOT, you could be running fairly low fuel pressure especially with upgraded injectors, bad deal... If you are just adding a chip or some 160cc stock nozzle injectors, I wouldn't worry too much but go much bigger and fuel system is something that needs to be looked at as well as the HPOP, as well as the turbo...
Renteria1217
Apr 16, 2015 11:38 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
